U-TUBE BUNDLE HEAT EXCHANGER FOR HEATING WATER IN TANK
Hello heat transfer gurus
i need to calculate the surface area of the
U tube bundle heat exchanger to heat the water
inside a water tank .
the U tube bundle is a removable type,
you install it by sliding the U tube
bundle into the side of the water tank
and bolting it on.
hot water enters the U tube bundle heat exhanger
and exits at a lower temperature.
the tank water is heated up by the heat transfer
from the hot water in the U tube heat exchanger.
1. any online calculators or excel calculators
which can do this.
2. anyone done something similar.
thanks...
and bolting it on.
which can do this.
thanks...
RE: U-TUBE BUNDLE HEAT EXCHANGER FOR HEATING WATER IN TANK
((ro^2 - ri^2)*pi^2)/2 for each u tube section (this assumes the bend radius is uniform).
