ASCE SLS combination for seismic
Hello dear engineer. I want to know, which load combination i need for use when I check serviceability limit state using seismic load.
RE: ASCE SLS combination for seismic
For conventional, code based seismic design in the US, I don't believe that there are serviceability drift checks. You simply have to adhere to the rather liberal (~h/40) drift limits specified in ASCE 7 for strength level design.
Different drift limits apply if you're doing extra-code design such as performance based design but that, then, is another kettle of fish and much is left to the discretion of the design team.
To add to KootK's comment,
Design based on ASCE 7-10 in the US gives you some "help" by removing the CuTa cap on your building period. So in a way, it is a sort of "serviceability" check (though not labeled as such).
You check the non-period-capped drift against Table 12.12-1 and the exceptions/notes in Section 12.12.
