Draft Form - Square
Draft Form - Square
I have problem with VBScript. I need to use DRAFT in my model with option Draft Form -> Square. When I'm using GUI it is working fine but I need to implement it into VBScript but there is no such code for changing Draft Form form Cone to Square. If someone had similar problem please write me about it.
Chears,
Konrad
CODE --> VB
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
Dim shapeFactory1 As Factory
Set shapeFactory1 = part1.ShapeFactory
Dim reference1 As Reference
Set reference1 = part1.CreateReferenceFromName("")
Dim draft1 As Draft
Set draft1 = shapeFactory1.AddNewDraft(reference1, reference1, catNoneDraftNeutralPropagationMode, reference1, 0.000000, 0.000000, 1.000000, 0, 5.000000, 0)
Dim draftDomains1 As DraftDomains
Set draftDomains1 = draft1.DraftDomains
Dim draftDomain1 As DraftDomain
Set draftDomain1 = draftDomains1.Item(1)
draftDomain1.SetPullingDirection 0.000000, 0.000000, 1.000000
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("Body.2")
Dim shapes1 As Shapes
Set shapes1 = body1.Shapes
Dim constRadEdgeFillet1 As Shape
Set constRadEdgeFillet1 = shapes1.Item("EdgeFillet.5")
Dim reference2 As Reference
Set reference2 = part1.CreateReferenceFromBRepName("RSur:(Face:(Brp:(Pad.3;2);None:();Cf11:());WithTemporaryBody;WithoutBuildError;WithSelectingFeatureSupport;MFBRepVersion_CXR15)", constRadEdgeFillet1)
draftDomain1.AddFaceToDraft reference2
draftDomain1.NeutralPropagationMode = catSmoothDraftNeutralPropagationMode
Dim reference3 As Reference
Set reference3 = part1.CreateReferenceFromBRepName("RSur:(Face:(Brp:(Pad.3;0:(Brp:(Sketch.4;11)));None:();Cf11:());WithTemporaryBody;WithoutBuildError;WithSelectingFeatureSupport;MFBRepVersion_CXR15)", constRadEdgeFillet1)
draftDomain1.NeutralElement = reference3
draftDomain1.SetPullingDirection -0.000000, -0.000000, 1.000000
Dim pad1 As Shape
Set pad1 = shapes1.Item("Pad.3")
Dim reference4 As Reference
Set reference4 = part1.CreateReferenceFromBRepName("FSur:(Face:(Brp:(Pad.3;0:(Brp:(Sketch.4;13)));None:();Cf11:());WithTemporaryBody;WithoutBuildError;WithInitialFeatureSupport;MFBRepVersion_CXR15)", pad1)
draftDomain1.PullingDirectionElement = reference4
part1.Update
End Sub Chears,
Konrad
