structural cracks in a domestic building
im new to the internet and am seeking information on how major structural cracks can be repaired in a building. any ideas. any reply would be much appreciated
RE: structural cracks in a domestic building
And if it's a "MAJOR" structural crack, perhaps you need to be looking at total replacement and not just repair.
regards
So you'll need think about what's causing the cracks and try to stop whatever is causing them. Could be foundation settlement, could be faulty concrete, could be frost heave, could be ....
Visit your local specialty supplier for crack sealants.
Epoxy injection may fill it so that water won't get in, but filling it will not prevent further cracking or fix the cause of the crack.
If the structure was improperly designed, God onlt knows what you might need to do.
In addion to the items Watermelon indicated settlement and movement can be caused by building on expansive clay, compressible or improperly compacted fill soils, or improper maintenance around foundations, improper materials, faulty design, equipment vibration, vehicle vibration, physical damage ..
Cheers
First, remember the forum in which you are seeking assistance. Engineers like detailed, specific information. A clear, concise account of your problem with all pertinent details will not only gain you credibility, but also help others to provide insight.
Is your building in a seismic region? How old is it?
If a one-time event like being hit by a vehicle or an earthquake is cause of the cracks, then I agree with epoxy injection as a solution, however if it's a water problem, settlement, etc., repair of the concrete is only part of the overall fix.
