ASTM A519 Gr 4130 mill test
thread177-351078: Mill hydro test pressure per ASTM A530 for A106 pipes
The ASTM spec for low alloy tubing does not specify a mill hydro test. It is neither there in the recommended supplementary tests.
A106 and A213 specs do call for mill hydro tests.
What is the reasoning why the A519 excludes the mill test.
RE: ASTM A519 Gr 4130 mill test
Typically we would UT or ET (or possibly flux leakage) test this type of tube.
This is hot finished, so it will be machined and heat treated before it is used, usually.
