DWSI Radiography (Using X-ray) for Boiler tubes
Dear All,
I am facing a problem for boiler tube RT. The dia of the tube is 38mm and space between adjacent tubes is that you can insert two fingers. Our contractor is using X-ray tube and it is impossible to do DWSI as source placement at 90 degree is really not possible. The contractor is not ready to use a gamma source for it. What other options could be availed to cover the joint as per ASME requirements?
RE: DWSI Radiography (Using X-ray) for Boiler tubes
ukmet,
Get another contractor !
If you are the client you say to your contractor, RT those tubes - they then propose to you how they will do it.
They do not tell you how they will RT it !!!!!
Clients quite often stipulate X-ray (for its better quality) because they are sitting in a nice, comfy office thousands of miles away but the reality is you cannot fit an X-ray set in a lot of places in a boiler.
As per ASME requirements you cannot RT a 38 mm OD tube DWSI with gamma or X-ray.
It is either DWDI or DWDI (Superimposed).
Gamma is used every day in boilers all over the world - what is your contractors problem ?
Shane
ASME I does not require RT for these tubes. The requirements for RT are to be agreed upon by Purchaser and Manufacturer/Contractor within the Contract.
