Help with save as command in Teamcenter 11
We just recently upgraded to Teamcenter 11. Prior to the upgrade when I would do a save as, the majority of the fields would automatically populate with information from the existing file that I was using to save as. This was nice because many times much of the information did not change. Since the upgrade all the fields are empty. Is there a setting I can change to get the fields to populate using info from the existing file? Thank you in advance!
Thank you,
Trent
NX 11.0.1.11
RE: Help with save as command in Teamcenter 11
Siemens changed the Teamcenter preference "CopyFromOriginal" to "false" OOTB, starting with Teamcenter 10.1.3.
Search GTAC Solution Center for PR7283152 for a document talking about this change.
This may be the reason you are seeing a different behaivoir in Teamcenter 11.
