How to get Peak Response (only) for Sine Vibe Analysis
Hi Folks,
I am trying to find a way to get NASTRAN to output just the peak response for element force for a sine vibe analysis (sol 111). If I use the straight FORCE(print) = case control card I get the forces at each frequency which I then have to find the max of manually. Or I can use XYPEAK to get the max/min results, but as far as I know that requires a separate XYPEAK card for every DOF for every element (and I have thousands of elements). There has to be a better way, doesn't there?
-Mike Beda
-Mike Beda
RE: How to get Peak Response (only) for Sine Vibe Analysis
I'm now thinking the only way to get the peaks alone is to write an ALTER file. Has anyone done this with nastran's output modules?
-mB
