Multistage Pumps VS Sundyne Pump
Respected Sir,
I have a question regarding comparison between Multistage Pumps vs Sundyne Pump. I am asking generally not for specific parameters.
So Kindly provide your views on why Sundyne is good over multistage or vise versa. and comparison between these two.
If you have any presentation or document where i can refer this topic kindly provide.
Thanks & Regards,
Mitesh.
Thanks & Regards,
Mitesh.
RE: Multistage Pumps VS Sundyne Pump
Lets talk specific -
Process parameters are as under.
Process fluid- light nephtha
Max temp - 150 C , Min temp - 52C
Viscosity - 0.56cP
flow - 27.1 me/hr
Head - 312.8
NPSHa - 16.96
Hy kW- 15.06
In the above case i have 4 offers from different pump manufacturer. In that 4 , 1 of them Sundyne.
Can anyone tell me shall i go for multistage or sundyne? (Efficiency or utility criteria do not consider as of now)
Mitesh
Johnny Pellin
I don't think anyone can advise you here if you don't set out what criteria you're going to use to decide.
cost?
Reliability?
space?
Delivery?
This is like asking someone what kind of car you should buy...
to get a better response narrow down the issues a bit.
JJPellin : Sir i already search "Sundyne" in this forum but i did not get specific difference between sundyne vs multistage pump.
Once again I am clarify my query. I just want to know which is the better option multistage or sundyne.
Kindly provide your views with specific reason.
Thanks in advance.
Johnny Pellin
Pitot tube pump
Axial split multistage
Radial split (tie rod) multistage pump
Multistage overhung pump
Sundyne
Johnny Pellin
Can you please provide me the details or reasons why you want to go for multistage pump over sundyne pump?
To all experts - I want to know which is good selection sundyne or multistage pump?
Thanks and Regards.
You have had a reasonable explanation given, what more do you want.
