AutoCAD plot style/color dependent tables
Can someone please tell me how to change my plot style table from a style table (.stb) to a color dependent (.ctb)table and/or vice versa? Right now in a particular drawing it has the STB options only and I'm trying to get back to my ctb tables that I usually use. This is a mystery (that its suddenly using stb's for this particular drawing) to me and the AutoCAD user book isn't much help as usual in clarifying this. Thanks.
RE: AutoCAD plot style/color dependent tables
If you go into menu tools, then select "options"
> go to the "plotting" tab, and you shld be able to select
"colour dependnt plot styles"
(sounds like it's set at "named plot styles" at present.)
I thnk this should allow you to then go to page set-up and select your desired ctb file.
hope it works ! regards,
Cenkos :)
and still the options in the plot style table area of the plot dialog box shows only stb's. And I can't get it to give me the ctb styles. I'm stumped.
Thanks for getting back to me.
when you go into your (file)- Plot Style Manager does it display ALL the style tables, ctb and stb ?
mine contains both - but when i go to page setup to assign a style table to my drawing it only displays the ctb's on mine !
is it possible they are in a different directory ? ...
...when you are in plot style manager can you browse... ?
(we cant but it may be the way our company standard styles are set up/saved)
ooh, dwhlst on style tables.. :D Does anybody know how to get a drawing to retain style table eg BIND thm to the drawing. i created a new style table yesterday to deal with
a diff consultants weird pen settings ! (lol) - however its auto stored on my C:/ and not read off the network. (so other people accessing them in future wnt be able to 'find' that table! ) is it possible to bind those setting into a drawing?
worth a look, until someone else peers in here with the correct button to toggle !! lol :D
If you use the AutoCAD 2000i or 2002, the command CONVERTPSTYLES is the key of your problem.
In AutoCAD 2000 you should copy and paste the objects into a new drawing with color plot styles.
Farzad
CONVERTCTB and CONVERTPSTYLES are your two routines to go from color to named and named to color like FH said above.
Great help! Hope I can help out oneday too.
