Fatigue calcs for non-integral equipments
Dear All
Recently I was working on fatigue calculations for a vessel as per ASME BPVC Sec.VIII-2. I wanted to exempt the vessel from detailed fatigue calculations as per fatigue screening methods but exemption of the vessel was not possible with any of the methods.
Then the owner has asked to change the nozzles from pad reinforced to self reinforced. Even with this method the vessel cannot be exempted. However, the owner wants the vessel with integrally reinforced nozzles.
If an equipment cannot be exempted from detailed fatigue calculations, is it against the code to make the vessel with nozzles that are reinforced with pads?
In other words if I want to do detailed fatigue calculations is it a must that the vessel shall be integrally fabricated or is it just some recommended practice?
Warm Regards
Warm Regards
RE: Fatigue calcs for non-integral equipments
That said, integral construction normally has a much higher likelihood of passing the fatigue calculations without additional modifications. Also, although I've never had to do it, my understanding is that performing fatigue calculations on a nozzle with repads is not trivial. You are introducing large areas of 'no penetration' analysis to your FEA results, which will be painfully slow to analyse.
Cheers,
