invalid hardcopy configuration
I have plotted from the same computer for about 4 years with no issue. The ACAD version is 2005. Operating system is windows 7. Recently, on my attempts to plot, I get this message " an invalid hardcopy configuration" and I get no plot. What does that mean and how can I have the computer to plot again?
RE: invalid hardcopy configuration
What printer ARE you using?
What are you printing and how are you specifying plot size?
AutoCAD currently allows specific plot configuration files (PCP or PC3, I can't remember exactly the file extension) and although I don't know if ACAD 2005 did this, it did have something equivalent even then. That file is very user-customizable. Enough that I often say "I'm no touching that".
STF
STF
BTW, do you have your inkjet sorted out yet? Have you tried a HP driver update? Thinking back a few years, I remember DOWNgrading a HP print driver from "version 6" to "version 5" and getting good results. Whether I did that for AutoCAD or for some other reason, I don't remember.
STF
B.E.
You are judged not by what you know, but by what you can do.
So you don't need to explain again...
STF
Oops! I picked the wrong one above; this is it:
invalid hardcopy configuration - Autodesk Community
forums.autodesk.com› AutoCAD› Forum
Same author as above
