what kind of acceleration sensor for a spindle head for machine tool
what kind of acceleration sensor for a spindle head for machine tool ?
1) a light acceleration sensor
2) small one
thank you
2) small one
thank you
RE: what kind of acceleration sensor for a spindle head for machine tool
I think an Endevco 222 (from memory) is a light small accelerometer.
Cheers
Greg Locock
sensitivity:
speed= 1000 RPM
but there are 2 gears (20 teeth) and 4 bearings to monitor.
sensor for a classical tool machine
environmental factors:
work oil for tool machine
So, try the Endevco, I'm sure they have an online catalogue.
Seal all your microdot connections with Silastic or equivalent to prevent oil ingress.
Cheers
Greg Locock
http://www.imi-sensors.com/series.asp?series=607A61
it is made for this purpose.
You might also look at:
www.processvibration.com
there is a spindle monitoring setup available there.
C. Hugh
