Foundation Settlement & Raft on Piles
Dealing w/ high water table with moderate seismicity here..
Geotech recommended using a raft on pile to bedrock at 40-ft below grade (some at 80-ft)
1. When does it trigger for geotech to recommend using piles over a mat foundation? If a mat settles one or two inches over a large area relative to other corner, does it really affect anything if functionality of the structure is not compromised? Is there a code recommended value?
2. Method of getting an idea of designing the raft on piles: I've read a paper recommending first running an analysis of the raft as a slab-on-grade w/ soil spring or subgrade modulus. Then check for settlement. If the settlement is less than 3 inches, then no need for piles. otherwise use piles and re-iterate the analysis. What is basis of this approach?
I always appreciate any feedback here.
RE: Foundation Settlement & Raft on Piles
Seems like you would expect a bit of differential settlement if there were no piles or ground improvement
If you use "soil springs" for your soil-structure interaction, you need to consider long term consolidation, as oldestguy has noted. And keep in mind the equivalent soil spring will not be constant for the entire foundation footprint.
