mesh generation failed! imprecise vertices? Help needed (pics attached)
Hello ,
I am trying to hex mesh a foam part as shown. When i try to mesh i get the mesh generation failed due to a problem in the propagation of mesh seeds error. I go to query- geometry diagonistics and find two imprecises vertices. Are they causing this problem? How to fix this?
Thanks!
Thanks!
RE: mesh generation failed! imprecise vertices? Help needed (pics attached)
I've used it to remove redundant vertices from parts which I then hex meshed. Here's the blurb from the users guide:
Abaqus/CAE does not support all of the meshing techniques on regions that contain virtual topology. Specifically, Abaqus/CAE does not support the following:
