Material Grade
Material Grade
Material Grade
Dear All
Is that possible to have a fitting that has two different grades in the same time A420 WPL6&A860 WPHY52.
RE: Material Grade
Dual certification of certain, overlapping material grades is permitted by ASTM. Check the chemistry and mechanicals on the test reports to ensure correctness for dual certification.
RE: Material Grade
dear sir
you mean it must have two different certificates? for each grade.
is that ok if in one certificate we have two different grade?
RE: Material Grade
One inspection certificate can state dual certification.
RE: Material Grade
The dual grade material is the material has the mechanical and chemical properties meet the requirements of two types of steel. Both grades will be stamped on the material.
RE: Material Grade
The standard A860 is more strict in both chemical and mechanical requirements, you can use WPHY 42, 46 and maybe WPHY 52 as WPL6 , when the tensile strength is not over 95 ksi, the yield strength,elongation and charpy values are lower for WPL6 with not maximum values. The WPL3, WPL8 and WPL9 are different material, the chemical requirements are different. About the marking all depends in the supplier and customer agreement
