Tolerance for weldment's angular dimension
Why does ISO 13920 say that the length of the shorter leg determines the applicable tolerance for the angular dimension of a weldment? Wouldn't the deviation be dependent on the longer leg?
RE: Tolerance for weldment's angular dimension
Because the longer leg is acting as implied datum.
Thanks, CheckerHater. My shorter leg is on a datum, so I'll base the tolerance on my longer leg.
