Design of quarter-turn, low-speed, high-side-loaded spline
I am checking a calculation for the design of some splined joints as follows:
-Involute fillet root side fit splines
-Externally splined items are simply-supported shafts with the splines on cantilevered ends
-Internally splined items are bell cranks on each end with approximately quarter-turn rotation
-Loading is torque plus side force due to connected linkage rods: high load, low speed, low cycle, not fully-reversing
-Materials are nonferrous and ductile and are immersed in saltwater
-Size, weight, and cost are less important than schedule, so conservative hand methods are preferred over FEA
The calculation has changed hands a number of times in development and combines a hodge-podge of different analysis methods: Dudley from Machinery’s Handbook, the gear tooth from “beams of relatively great depth” in Roark, and shaft bending/torsion. I’m not convinced that it combines stresses correctly in all of the right places, or that the allowable stresses used are appropriate in all cases (some are based on my company’s traditional fractions of yield, and some make a leap from nonferrous materials to Dudley’s allowables for steel).
The design load is a very unlikely worst-case over 50% greater than what should ever be experienced in operation. I believe that failure will be dominated by stress rather than wear, and fatigue is not a concern. My impression from researching is that this is an unusual application without much precedent in the literature. The best reference I’ve found so far is Volfson, “Stress Sources and Critical Stress Combinations for Splined Shaft,” which does a good job of describing the bending and torsion stresses and the load distribution between teeth, but punts to FEA for the tooth stresses.
My general question is what design guidance the community recommends for this situation. I also have some specific questions:
1. Does analysis of spline tooth stresses typically neglect torsional shear components beyond the minor diameter?
2. What approaches other than Volfson have been used for distributing tooth loads due to side force?
3. Dudley’s S3 for the internal spline is “tensile stress due to the tangential force at the pitch line causing bending of the teeth.” I interpret this as a radial normal stress component (tooth bending) because there’s no factor to account for hub thickness (if it were hub bending). The other two components, S1 and S2, are clearly circumferential stresses (due to radial and centrifugal loading). This would be a state of biaxial stress, but Dudley adds all three directly, which doesn’t make sense to me. Am I misinterpreting the direction of S3, or is there a failure theory where principal stresses add, or am I missing something else entirely?
Thank you in advance for any input you can offer.
RE: Design of quarter-turn, low-speed, high-side-loaded spline
I've actually performed a calculation remarkably similar to this one, although probably with less risk/exposure than what you're describing.
'Cantilevered splined shaft, with bellcrank mounted, with radial load due to linkages, with approximately 90 degrees of working range' very accurately describes the suspension bellcrank arrangement of many high-end open wheel racecars.
Not sure if you are willing to spend money on scholarly articles, but here's one that is extremely applicable:
http://www.sciencedirect.com/science/article/pii/S...
jgKRI, thanks for the reference. I love a good research paper as much as the next guy, but some of the terminology in that abstract strikes me as more academic than applied. Is this what you based your calc on?
First, I would point out that the fillet root, side fit spline you are proposing to use is not really a good choice for how you are using it. This type of spline is only good for transferring torque, since it does not provide precise radial alignment between the mating parts. If you use this type of spline joint, you should provide some other features to radially align the mating parts, and only use the spline to transfer torque.
Torsional deflection of the spline tooth flanks can be a concern with wide face widths and small root diameters. Lead correction is often used to compensate for torsional wind-up in the spline teeth, so that better load distribution along the spline tooth face width is obtained under loaded conditions.
tbuelna, thanks for your input. We originally planned on a major diameter fit to transfer the side load. However, the operating environment tends to result in deposits, and the people who oversee maintenance requirements objected to the tight clearance of the major diameter fit. We switched to a side fit expecting that it might drive the design but could be made robust enough to work. Was that a bad expectation, and what combinations of fit and/or other supporting features would you suggest? Thanks.
THHV-
Attached is a (crude) sketch of a side fit spline joint arrangement with radial locating features I had in mind for your cantilevered shaft and bellcrank attachment. I would recommend using bushings at the two journal interfaces, since the side fit spline will have some clearance (backlash) between the mating tooth flanks. The spline backlash will allow some relative sliding at the journal contact surfaces that would make them susceptible to fretting.
Ideally, since this assembly will be submerged in salt water, you would add o-ring seals at each end of the joint and fill the space with grease. If using seals and grease lubrication is not possible, then I would recommend using a high-strength thermoplastic material for the bushings, such as PEEK, Torlon or Vespel.
Hope that helps.
Terry
