Strain Gauge Pressure Transducer to Give Force
I am having a little trouble getting some clear information with regards to the importance of pressure sensor surface area.
Say I am using a pressure sensor with a 30mm flush diaphragm, mounted so that its sensing head is flush with the inner diameter of a pipe, used to move a non homogenous fluid.
Imagine it gives me a reading of 30 Bar - firstly, could I safely assume that the pressure around the whole inner diameter of the pipe (in line with the pressure sensor) is 30 bar?
Also - if I wanted to translate this to a force, what area should I consider, the inner circumference of the pipe and the diameter of the sensor? Or just the area of the sensor?
I don't feel like i've explain myself clearly - but if anyone could have a go at a reply and maybe we can go from there.
Thanks.
Jericho.
RE: Strain Gauge Pressure Transducer to Give Force
Pressure is pressure, it makes no difference how large the surface is.
It might be easier to think in a unit like psi which is descriptive (pounds per square inch)
If you have a 1" diaphragm or a 3" diaphragm the transmitter sees the same pressure 30 bar
Sorry I haven't explained it very well either
