Taking measurements on a smooth floor
I've got a smooth (reinforced) concrete floor I need to take vibration measurements on. My experience using some type of probe is: it's not particularly accurate. I almost always drive some type of (short) masonry/surveying nail and then use a magnet attachment to take measurements. However, the client I am working with has apprehension about driving permanent nails. Can you suggest a alternative to a permanent attachment where I could get reliable readings? Thanks.
RE: Taking measurements on a smooth floor
Cheers
Greg Locock
Perhaps you are using something like this in which case neither suggestion is helpful!
http://www.globalsources.com/si/AS/Xiamen-Niell/60...
Cheers
Greg Locock
Cheers
Greg Locock
