Low breakout torque thread
Im designing a milling/drilling machine that uses 1.750" diameter low alloy steel drill rods. Im needing a connection for connecting multiple drill rods together. currently, we use a 1" square drive and dowel pin, but I'm not totally happy with it. Does anyone know of a thread that will permit torque through etc, but will facilitate easy breakout? Im guessing it may be something like a twin start high helix thread or something similar to a 1" AMT thread.
regards
Matt
regards
Matt
RE: Low breakout torque thread
Breakout torque will still depend on how tight the joint was made in service.
Ted
Im fairly familiar with typical API threads (I work in the oil industry). However, most of them require being torques up and broken out with power tongs. I was wondering about the threads used in tool holders for live tooling?
Cheers
Greg Locock
If you're talking about typical CNC machines, the tooling is not directly held in place by a thread of any kind- there is almost always a tapered interface. Sometimes with keys, sometimes not. Thread forms are used only to pull the taper tight- the thread sees tension but does not transfer torque.
What I was referring to earlier is used on ejector drills (https://www.google.co.uk/imgres?imgurl=http%3A%2F%...)
Im leaning to a 4 start acme thread or something similar I think. A screwed joint is ideal for what I want, I just dont want the high breakout torque associated with it.
Consider one of the coarser Acme thread, but relieve/wipe the first two or three threads so that your pin(male) threaded post bottoms out in the mating (female) component.
Good Luck
Rick
Thanks, although Im not totally sure what you mean?
I have modelled up and 3D printed a modified stub acme 4 TPI 4 start tapered thread which looks like it would work well. However, the lead is so steep that if the thread was not torqued up at all, the lower rod would unscrew from the pin and drop down under its own weight....
Its sort of a trade off between not backing off too easily, but not requiring too much torque to undo.
