When will NX be able to use convergent models with drafting and manufacturing?
In the Siemens article... Link ...it says:
"Unite the two convergent bodies first, then unite with the B-rep solid body patch we just created in the previous steps. You are left with a new, complete solid body that can be used for other applications, whether it be machining or 3D printing to create a brand new part that can be installed out in the field."
I am still unable to use convergent bodies for manufacturing geometry. Does anyone know when this will go live?
11.0.2
RE: When will NX be able to use convergent models with drafting and manufacturing?
I didn't read anything in that article that stated NX could do anything other than perform convergent modeling - only that the model could be using for other applications like machining or 3D printing. It didn't quite state that NX CAM would support a convergent model, in other words.
Tricky, huh?
If you have access to GTAC, look over the NX11 What's New Guide. I didn't see any topics about convergent models in the CAM section. However, in the CAD section under Convergent Modeling there are 2 sentences that probably lead to more questions, if not at least 1 important one relating to "other applications":
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
Is anyone aware of preview projects regarding manufacturing convergent models?
11.0.2
I got the response from Paul Bevan that "the next NX version *" will handle convergent models in drawing views. ( * The next version should be NX12, due this autumn.) Note that he responded this spring and features can be skipped until final release.
Note, the quote "You are left with a new, complete solid body that can be used for other applications" is wrong.
The result is that when one unites a solid to a convergent model, NX (Parasolid) will first convert the solid to a convergent body, then unite these. The result is , and will probably always be a convergent body, a facet body.
Another option is that NX can convert between different facet formats. I think (?) that if one imports say a stl file, that can be machined in NX . A convergent model should be able to converted to this older facet format.
Tomas
It would be nice if development could comment on this.
11.0.2
