Ansys Workbench APDL select volume
I try to select volumes via APDL in ANSYS Workbench but command VSEL return empty selection. So I check the model by /STAT,GLOBAL and there are no volumes (keypoints, lines, areas either).
I know the trick that I can access volume via Named Selections using CMSEL command but is there any way to access the volume without CMSEL command?
Best regards
Jrz
Best regards
Jrz
RE: Ansys Workbench APDL select volume
allsel
and then:
vlist
If the list comes back as empty then there are no volumes in your model, so regardless of whatever you try and do (CMSEL or otherwise) you are asking ANSYS to list or show information on an entity which doesn't exist. It sounds like there's nothing at all in your model actually, but try:
allsel
gplot
and see what ANSYS shows.
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
L_K: I try to select solid elements only that are attached to the volume(s) then do some operations on them. When I use CMSEL, surface elements are select too.
Drej: When I'll be back at work I'll try your advice. But what I remember ANSYS Workbench tells me that there are elements and nodes only, no geometry, that's odd for me.
If your solid elements are SOLID186 (default in Workbench Mechanical), this code should select only the solid elements.
CMSEL,s,box
esel,r,ename,,186
, where box is named selection of the body in question.
Maybe there is a more sophisticated way but this should work.
Ansys workbench does not transfer geometry to APDL so commands such as VSEL wouldn't work. A named selection on volume in workbench selects the elements. All others entities will select nodes associated with the geometry for use in APDL.
Best regards,
Jason
Drej: As sk_cheah said not possible.
L_K: Thanks for
CODE --> APDL
Why I missed this command is mystery for me.
At this point I stay in combination of the CMSEL command or
CODE --> APDL
Thanks all of you.
