How do I realise a high pass filter in microstrip
Wessex (Electrical)
I am familiar with techniques for low pass and bandpass
but have not yet come across a high pass.
Can you help?
Can you help?
RE: How do I realise a high pass filter in microstrip
regards,
lkuzu
if you want to design correct microstrip filter try with "filter synthesis program" (like Serenade,Microwave office),this is
very simple way.HFSS is very good only for 3D simulations,I think that it is unduly to use 3D simulator for microstrip filter.
suhair al-ali
A shunt inductance will need access to the ground plane. This can happen by designing your filter near the edge of the circuit board or through via holes that drill through the substrate.
Good luck,
Buding.
he could could design a Filter with series capacitance and parallel inductunce.
