Hydrostatic test of pressure vessel
w.r.t the attached image explaining Hydrostatic test process (link http://www.inspection-for-industry.com/vessel-pres... ) its given that pressure is increased in stages. since the water (if used as test liquid) is incompressible how is it possible to increase to the desired pressure? once the vessel is filled fully, the pressure varies from 0 at top to P=rho*g*h at the bottom. How is it possible to raise the pressure?
RE: Hydrostatic test of pressure vessel
Similarly your vessel is not a truly solid object, but expands under pressure / stress.
So the amount of water required to raise pressure from 0 at the top to your test pressure might be very small, but then so is your pressurising pump / piston.
This FAQ is about thermal expansion, but the principle is the same - increase in volume versus increase in pressure http://www.eng-tips.com/faqs.cfm?fid=1339
It's probably somewhere between 1 x 10-4 and 1 x 10-3 in terms of volume to get to your test pressure - small but finite and measurable.
A lot depends on the volume of your pressure vessel relative tot he volume of your pressusiing pump / piston
How did that 4th formula increase in volume due to increase in pressure come? please find the attached file showing different formula.
If you're trying to find volume of water required to raise the pressure in the vessel by a certain pressure then you also need to include the Bulk Modulus of water - 2.3 x 10^9 Pa
