Abaqus/Python - Extracting Connectivity of Surface Elements
Is there capability within the Abaqus/Python API to extract the connectivity of a surface (such that the element definitions are 2D) from an ODB file? I have only been able to accomplish extracting the 3D elements which are used to form a surface, but I am only interested in the faces.
RE: Abaqus/Python - Extracting Connectivity of Surface Elements
Simple workaround (when using A/CAE):
- Create a skin in the property module
- Create a surface section in property module and assign that to skin
- Assign surface element type in mesh module to skin
After the analysis you can take the connectivity of the surface elements.
This won't guarantee that the final numbering is in any particular order that would correspond to a 2D element though.
Example:
print session.odbs['Job-1.odb'].rootAssembly.elementSets['SKIN'].elements[0][0]
