Pwp dissipation using CPT
Engineers,
I have a question about the cpt.
I have worked in central florida, USA, for few years and noticed that projects involving CPT it is not required to perform PWP dissipation.
On the other hand, i have worked in few other projects like in Mexico and noticed that the engineer in charged does require pwp dissipation.
My question is: is it mandatory to run pwp dissipation or not?. At least the projects in mexico are dry stack embankments (silt), so i guess the pwp dissipation is useful for predicting consolidation ratio. But in FL, everything is pretty much sand, so i guess pwp dissipation is not needed as sands do not hold water pressures.
Please correct me if i am wrong.
Thanks.
Thanks.
RE: Pwp dissipation using CPT
For the clay layer is required if you need the time consolidation, cv but you have to read till the pwp disappear.
Also, the parameters from the CPT dissipation test are horizontal rather than vertical, i.e. you get ch, not cv.
L0k, specifically what value do i get from CPT dissipation for liquefaction analyses?, I have never seen that before.
Please let me know,
I've spent today looking over CPTu data on a PVD job (the embankment is constructed). We still have excess pore pressures. I guess the consolidation and strength gain are not complete.
f-d
ípapß gordo ainÆt no madre flaca!
This is the pore pressure data I use for liquefaction analysis.
