Material Grade
Material Grade
Material Grade
Dears
Can I use fitting material A420 WPL6 instead of A234WPB.
RE: Material Grade
That depends on a number of factors, like the application, service conditions, design code, engineering secifications, etc.. Without such information questions like these are impossible to answer.
RE: Material Grade
Keeping in mind what XL83NL stated, often yes. SA420 WPL6 is often used in lieu of SA-234 WPB when impacts are required.
