Manual ball valves for steam isolation
Hi
The customer's maintenance engineer is requesting manual ball valves for manual steam isolation (double block and bleed). I have used gate and globe type (Spirax Bellows Seal) in the past with good result. I prefer ball valves as automatic steam isolations. Something like a Keystone KTM.
The idea of manual ball valves as steam isolations seems a bit strange to me. I have mentioned that the operating torque might be a bit high and ball valves are not meant to opened slowly, which is preferred on steam. We could use a geared hand wheel to help with manual handling, but are harder to find and reduce the compactness that makes ball valves great in the first place.
Maybe I need to be a bit more open minded
What's your thoughts?
Kind regards
Kind regards
RE: Manual ball valves for steam isolation
Hello rusty sim,
You seem to have a good grip on possible valve problems.
My comment:
As valves for all other fluids, steam is all about size, pressure, pipeline layout, construction, application, quality and operation of the valves. (But for steam perhaps even more so.)
For smaller sizes and moderate pressures ball valves may well be a good and relatively cheap solution. Most problems with ball valves for steam are caused by not satisfactorily and soft seat sealings, which may be misformed by even minor leakages. Or, as you mention, they could cause water-hammer problems by not satisfactorily condensate drainage.
For all sizes and pressure steam valves you should be safe if you have a plant with correct condensate drainage, correct layout and correct (slow) opening and correct closing, disregarding type of valve. BUT: only by using valves constructed for the steam-pressure you are using, fabricated by renowned producers and designed for the application you have.
As known, incorrect layout and failing/missing condensate drainage causes more problems than different types of valves, if the valve in itself is suitable for the application.
Regrettably most steam plants will,at some point, have poor layout and misssing or incorrect/failing steamtraps.
Good luck!
MFJewell, the lines are probably 40-50 NB and valves will be ansi 150.
The manual valves would only be closed for maintenance of the heater or during commissioning. During operation steam flow to the heater would be controlled by an auto ball valve and globe control valve.
Hi again!
With the long periods between operations, and then the additional requirement of no leakage over a long lifetime, I would personally, without doubt, have used a globevalve or angle valve. The ball valve will have higher risk of impurities damaging the sealings, and should anyway be test operated more often than a globevalve to ensure OK operation.
A high-quality ballvalve construction will minimize the risk, but the price would probably be higher without gaining much against a globevalve in lifetime and safe operation.be higher.
A thight-closing globevalve with 'skirt' or coned globe would be better than a standard globevalve.
They are difficult to actuate- by "difficult", I mean in the sense that they are unnecessarily difficult to actuate in the same way that it is unnecessarily difficult to drive screws with a hammer.
At 150# class, PEEK seated ball valves are generally the right solution for automated steam block service. They will give better service life and tighter sealing than a metal-seated ball valve, which along with perhaps the triple offset butterfly at larger sizes is likely what you'd need above 150# class.
