Reference Text & Expressions
RE: Reference Text & Expressions
I do believe if these parts are in its own assembly you can click on each individual part with the right mouse button pressed and go to general and where you see the part number in the dialog box put a under score A1 after and so on with each part. This will create a bill of material with all them items separate but with only the correct part number. Try this and see what you get.
Thanks for these suggestions, though I should've been more clear. Extruding the text into each part is what I am after.
