differences between Safeti and Phast
what are differences between Safeti software and Phast software ?
RE: differences between Safeti and Phast
both are supplied by DNV
I believe safety incorporates phast within it, but uses the results to generate QRA type numbers ( risk contours etc)
Phast is specifically a dispersion tool / flame distance / explosion simulation , the results of which used to be incorporated into a QRA in a more manual way.
but depends on what you want - you need to ask DNV GL
