FRP uses for bridge repair/rehabilitation
I'm curious what other's opinions are about using FRP for repairs to concrete bridges. I have a bridge rehab under construction that involves repairing the ends of some PC beams and wrapping them with carbon fiber reinforced polymer. Yesterday I saw the repairs they have done so far (only a small portion) and was not impressed. I was able to tear off some of this stuff with my bare hands. This will obviously have to be done again. There is a very detailed spec for this stuff, but I'm not sure if anyone is reading it. The spec says to perform 2 direct pull-off tests for every 300 sf applied in accordance with ASTM D7522. From what I have read, an acceptable test occurs when the FRP is pulled off and some of the concrete it's bonded to pulls off with it. That definitely can't happen if I can pull it off with my hands!
I'm trying to figure out if what I'm seeing is just related to poor work and ability or something else. I have seen it used quite a bit to wrap reinforced concrete columns, and that seems to work quite well.
RE: FRP uses for bridge repair/rehabilitation
Usually the spec will detail the acceptable area of defects (X in2 in Y ft2), and methods to repair or remove and replace the defects.
I have been involved with FRP since 1998 for buildings and bridges and have seen some absolutely crap installations. Given the current large number of suppliers/manufacturers and the often inexperienced field crews who undertake the prep and installation I am surprised there are not more defects reported.
Exterior installations can be challenging too with "out gasing" of the substrate if there is a significant substrate temperature rise over the epoxy cure time.
