Selecting motor and gearbox
I need to review some criteria for design of electrically-driven machines, especially for proper selection of electric motors and gearboxes.
I know some of this stuff from an university course that I took some years ago, in Italy. I have some resources in italian but now I would like to study from a textbook in english.
I searched very long without finding anything that fits. Is it possible that this topic is not covered in american/british engineering programs? It sounds very unlikely to me.
Could you please suggest a good textbook for mechanical or mechatronic engineering students about the design of electrically-driven machines? Thanks in advance!
RE: Selecting motor and gearbox
Considering gearmotors, their task is to deliver a specified torque at a specified RPM. So your task is to calculate the maximum torque needed for your application. I suggest you find and study Engineering & Applications Guides from gearmotor manufacturers like SEW Eurodrive, Dodge, Nord, others. I recall that years ago SEW had a very detailed Engineering Guide used for sizing exercises for their gearmotors.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
With regards to electric motor selection - I didn't find anything with detailed guidance for selection, but "Mechatronics" (6th ed, Bolton) was useful for understanding how each type works and some factors affecting selection.
I second the vote for Shigley's book for the mechanics.
STF
Cheers
Greg Locock
I also searched a little further by my own and I found "Mechatronics with experiments" by S. Cetinkunt. Section 3.6 is titled "Actuator sizing" and it seems ok, but I haven't read it carefully, yet.
What is it you are trying to figure out? The mechanics of machines needed to understand gearboxes is not very complicated. An off the shelf gearbox is a black box, with gear ratio, efficiency, maximum speed, maximum, torque, mounting holes, and input and output shafts or connections. You should not really care what is inside.
JHG
And the torque capacity must exceed anything that can be applied externally.
JHG
