Does anyone have test data for J bolts?
thread507-416314: Curious as to why people are still using J-bolts
I have combed the internet for J-bolts test and have not found anything related to smooth J-bolts similar to those used for foundation bolts.
RE: Does anyone have test data for J bolts?
Edit: I read the thread you posted and it referenced a metal building erection failure due to poor bracing, where they used j-bolts that contributed to the failure. The overturning erection loads I'm referring to is the OSHA load specifying the 300 lb load 18" away from the column.
Link
Dik
http://files.engineering.com/getfile.aspx?folder=e..._'Slip_pullout_strength_of_hooked_anchors'.pdf
Can't get attachment to work
that's how engineering works. products need to be qualified.
why answer a question with another question when you're ignorant with the regards to the topic at hand?
