"Works of Art" - Structural load requirements
I have a "piece of art" a client is making for their client, and they have requested structural engineering for it.
They want to call it a piece of art. It will sit in an open space. Not sure yet if publicly accessible. It is very slender, basically a cantilever structure, on a tilt of 15 degrees, and about 16 feet tall. As such, deflection under wind is very real. Also, if any hooligan were to parkour up this thing, or people just lean on it for pictures, it will deflect quite a bit.
I can make it strong enough, but the deflection is a very real concern, even under it's own weight.
1) Does anyone know any relevant parts of code the pertain to "works of art".
2) Does anyone have any general guidance for stuff like this?
3) As a general question, if someone parkours up this thing, and it breaks, and maybe that kid gets injured, can the engineer be responsible at all? I would think so if it is reasonable to assume that this might happen. Thoughts?
RE: "Works of Art" - Structural load requirements
If this isn't sturdy enough to climb on then it needs to be behind a fence.
You can check the structure for the loading of a person climbing it. That might be the controlling case. People interact with public art, you should expect that.
There's nothing in the building code that deals with art specifically - in terms of the art's self-stiffness, etc. As a structural engineer providing engineering consultation/design, you would probably want to simply meet the code's general intent - i.e. life safety using similar levels of safety.
Just what I mentioned above - the issue is you can use ASCE 7 or other similar codes to estimate wind/seismic forces on it. But live loads? Your example of a parkour dude shimmying up the art would give me a sense of loading - such as two, 200 lb. individuals at various locations on the art - simultaneously.
You would be responsible for the public safety and welfare of the structural behavior of the art piece. Your loading criteria, if a lawsuit or claim was filed, would be judged based upon what other reasonable engineers would have done in your situation. I don't think a reasonable engineer would assume a 2.5 ton four-wheel drive truck with a chain pulling down the art is reasonable. But two individuals on it might be. Three? Four? I suppose it depends on the shape, size, ease of climb, etc. on the art. If this is a public display - then getting input from the city building department might be appropriate.
As long as the strength and stability calcs out, I would be fine with whatever movement you get. With large deflections (i.e. read flexible) you need to make sure you don't get any lateral torsional buckling of members!
Juston Fluckey, SE, PE, AWS CWI
Engineering Consultant
Mike McCann, PE, SE (WA)
If this structure is a slender cantilever that may have people passing underneath, or even climbing on top, then it seems to me that a code for design of road signs would be equally applicable to this structure.
But in general, if considering whether standard code provisions are applicable, just look at the consequences if the particular limit is exceeded.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Place n load distribution devices on the component or structure in a manner that simulates the anticipated load distribution. Simultaneously load each load distribution device with a downward vertical force, F, given by the following equation: F(lbf)=250(n+1)/n
Also search for "z614-14 Children's playspaces and equipment" which borrows the same language.
Engineering Wild *ss Guess?
I've done some art projects as well as military static displays. There are no "codes" for this stuff. I make this very clear to all parties involved. I also use lots of factor of safety. The art stuff is the hardest to deal with because the artist doesn't want you to interfere with the art. Make sure you inform the artist in writing of the potential issues. Nothing you do can protect against everything. You get a freak storm that causes your work to fail and the artist will be suing you. Artists can be that way. I recall an art display at a church which the church decided to move. The artist sued the church for millions.
