Bulk storage of moisture sensitive material
Hi
Can anyone help me in identifying suitable standards (preferably European/ British) for storing a moisture sensitive chemical in Bulk tank (40 Metric Tonnes capacity, climate of the country is very wet and cold (upto -10 degrees C)in winter and maximum 25'C in Summer. The Bulk Tank is yet to be built and I wish to specify it with any necessary accessories as required. The nature of the chemical is a type of polymer. It is easy to pump at normal temperatures up to 10'C. The tank could be a pressure vessel is required.
We would be using tanker deliveries in 20 Tonne lots.
