Conical datum features/ Linear Extruded Shape/ Complex Shape
Can a primary datum feature such as Conical datum features/ Linear Extruded Shape/ Complex Shape be specified at MMB?
In other words, can a cone be specified primary datum feature with an MMB modifier?
4.17-2009 states that the “irregular features of size” can be specified at MMB, LMB and RMB, but does not specify anything about any conditions (such as being secondary or tertiary ---not primary---) in order to be called at MMB and all the examples shown (unless I am missing something, which is entirely possible) that have the irregular features of size at MMB/ LMB are depicted with this datum feature being secondary and tertiary (not primary at MMB)
Any condition, that you are aware of, is applicable here?
I know the standard cannot cover every possible scenario, but I am wondering, if something is “forbidden” by other rules (and regulations) in the standard that I am not aware of.
RE: Conical datum features/ Linear Extruded Shape/ Complex Shape
John Acosta, GDTP Senior Level
Manufacturing Engineering Tech
How are you going to fixture a primary-datum cone? You have size and angle to account for.
JHG
A cone doesn't have a simple evaluation for size measurement and it doesn't have a simple locating or orientation evaluation when it is imperfect. If a cone is not significantly deformed, a conical fit resolves to a point and an axis, neither of which has a size, so in practice I would avoid any size related modifiers. As discussed before, my feeling is the 'size' of a cone, as depicted in the standard, is a side-effect of allowing variation in the location where a single diameter measurement is made. In order to 'see' that size, the cone has to be oriented and located in a particular frame of reference, so it has no unrelated actual mating envelope. Whatever value is desired can be found by moving to a different location on the body of the cone indicating that cones are always the desired size.
I am still trying to visualize a fixture. Forget about primary datum. The primary datum feature is the large, flat end opposite the point. The secondary, locating datum is where a Ø50mm ring with a 2mm radius fillet contacts the cone. Add a clocking feature if necessary. If the ring has a fixed height, you have sort of a functional MMB. The cone can have all sorts of weird configuration away from the Ø50mm ring.
JHG
We have a design similar (or almost similar) with the attached picture I found in one of the GD&T books and also in their resource online. Other datum feature called B (secondary) is used -to stop the remaining roation degree of freedom , but suffice to say that A is primary --as shown--
Someone questioned if A (primary) can be (legally) modified at MMB.
Also, the extended question was if similar approach can be used for Linear Extruded Shape and Complex Shape--kind of shapes shown in Fig. 4-3 ( f and g).
When I replied to begin with there were no other posts.
There isn't a way to inspect the cone 'size' without relying on pre-defining another feature as an orientation and location reference, so it hasn't got a size to refer to. A datum target on the cone? OK, but that's not a size of the cone.
Edited to add the attached PDF. Of course, in depicted cases A and B and C, nobody would argue that the simulator for datum feature B should be anything other than fixed as perpendicular to the simulator for datum feature A, regardless of how irregular the actual feature may be produced. Then in case D, why would the simulator suddenly need to be adjustable in angle? It would just be a conical surface, 179.8 degrees included angle, fixed, and perfectly oriented to the simulator for datum feature A.
It's just a revolved surface. Simulators for inclined planar datum features do not adjust in angle, so why would a conical simulator behave in this manner?
A cylinder locates in X and Y. If (when) the cylinder is below perfect form at MMB, the result is that it can move in X and Y. Z is controlled by some other feature. A cone locates in X, Y and Z. At anything other than MMB, how should your fixture account for an incorrect angle?
I have no issues with a cone as a secondary datum. It provides X and Y location. You can specify positional tolerances at secondary MMB. You can implement RFS by making your secondary fixture variable height.
JHG
I am not sure that referencing a conical primary datum feature at MMB has a real meaning.
Exactly.... that is my question, too.
Probabbly is legal, but not usefull.
So, final answer?
Anyone else can provide some input based on their experience-application based? Or even some paragraphs/ verses from the standard that I am missing.
Thank you again for your help
So just to be clear -- it's not necessarily a problem to have MMB on a primary datum (with a secondary datum still referenced).
John-Paul Belanger
Geometric Learning Systems
Compare '2009 4-20 and 4-21 to '1994 Figure 4-18.
I was referring to the OPs question regarding a conical feature as primary. I wasn't clear that I was only referring to the conical feature in question but I would have said the same thing about a plane as primary at MMB. You can do it but it has no effect. In the case of 4-21 the effect is profound.
I will assume that the proposed primary datum feature is fully defined with basic dimensions and toleranced with a single uniform equally disposed bilateral profile of a surface tolerance. If anyone has something else in mind, please say so.
A linear extruded shape (such as Fig. 4-3, illustration (f) of ASME Y14.5-2009) is an irregular feature of size. I see no problem with referencing it as primary datum feature at MMB. I'd say the datum feature simulator is the maximum material boundary of the profile tolerance, and the part is free to shift around within (and optionally make contact with) that boundary.
Planar, conical, and complex features (such as Fig. 4-3, illustrations (a), (e), and (g) of ASME Y14.5-2009) are not features of size. I think the standard is much less clear in this case, so I would try to avoid the issue where possible. However, you might want to look at para. 4.13 regarding mathematically defined surfaces.
Why did they ask? What were they hoping or expecting to accomplish with the change? Also, could you describe datum feature B (and any others involved) on this part in more detail?
I would be very hesitant to say this. If you accept that it's valid at all, I think it's hard to argue that the datum feature simulator shouldn't be shifted away from the true profile to the maximum material boundary. I'd be interested to hear your thoughts on this.
pylfrm
I agree with everything that pylfrm said, and I'll add a few additional thoughts.
The questions in greenimi's original post are difficult to answer, because they probe into areas that Y14.5 is vague on.
Y14.5's RMB and MMB concepts were built around regular features of size, for which the constraint effects of material condition are fairly clear. They are difficult to generalize to more complex geometry, especially shapes with special properties such as cones and wedges.
There are some clues in Y14.5-2009's section 4.16 on Rotational Constraint About A Datum Axis or Point. If we go through figures 4-29 through 4-32, some general principles are apparent:
-RMB means that the datum feature simulator does not translate or rotate, but progresses to make maximum contact with the datum feature
-MMB means that the datum feature simulator is fixed at the MMB and does not translate or rotate, or progress. Fig. 4-31 implies that the datum feature must make contact with the simulator, but this is not stated anywhere.
-[BSC] means that the datum feature simulator is fixed at the basic profile and does not translate, rotate, or progress. The datum feature does not need to make contact with the simulator if the rotational degree of freedom is restricted in both directions (as in Figs 4-29 and 4-30) but needs to make contact if the rotation is not restricted (as in 4-31). I've never been comfortable with this inconsistency.
There are also some clues in section 4.13 Mathematically Defined Surface. The primary datum feature in Fig 4-28 is a mathematically defined surface, but it's practically planar. The figure shows it referenced at [BSC], and the text states that the high points of the datum feature are aligned with its simulator. The text also talks about what would happen if the datum feature was applied at MMB or LMB, clearly indicating that these options are possible and legal. Whether these options make sense or not is another question entirely, of course.
Now we can go back to Fig 4-3 and assess which material condition modifiers (RMB, MMB, LMB, [BSC]) could be applied to each feature type as a primary datum feature. Here's what I would get:
(a) Planar. Only [BSC] makes sense to me. MMB and LMB are possible, but wouldn't make sense because the simulator (and thus the datum) would be shifted relative to the true profile. RMB would not work, because the simulator would have no curvature and maximum contact would not be definable.
(b) Width. This is a regular feature of size, so RMB, MMB, and LMB are well defined and make sense. [BSC] is possible but would not make sense, because the datum feature may not fit over the simulator.
(c) Spherical. Regular feature of size, so same as (b).
(d) Cylindrical. Regular feature of size, so same as (b).
(e) Conical. To me, this is similar to the planar feature type. Only [BSC] makes sense to me. MMB and LMB are possible, but wouldn't make sense because the simulator would be shifted axially relative to the true profile. RMB would not work, because the shape of the simulator doesn't change as it offsets (special property of cone). Maximum contact would not be definable.
(f) Linear Extruded Shape. To me, this is similar to the regular features of size. RMB, MMB, and LMB are well defined and make sense. [BSC] is possible but would not make sense, because the datum feature may not fit over the simulator. One additional detail here is that it's assumed that the linear extruded shape is "closed" like the one illustrated, such that the datum feature envelops or is enveloped by the simulator. If the shape were "open", then things might be different.
(g) Complex. Anything goes - RMB, MMB, LMB or [BSC] could all be applied. But it would be case specific - which ones make sense would depend on the particular geometry of the complex surface. The quasi-conical complex surface in Fig 4-3 (g) is very different from the quasi-planar complex surface in Fig 4-28.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
I get what you're saying, but I'd go further. I'd reject applying the concepts of BSC vs. RMB (I mistakenly said "RFS" in my previous post) to a planar primary datum feature. And cones, too, I think.
I think the discussion centers around this point: We don't reference a primary datum feature for its own sake, we reference it to act as a...reference. The ways we put "handles" on certain shapes does not compute with the rules of GD&T because some shapes don't have "size", or at least not in the traditional sense. In the cases of planes and cones, we might be able to imagine their own flavor of "size" as a variable thing, but not one that is independent of the "handles" we use to know those shapes.
what does the collective think about the attached drawing. Here, the primary datum feature is not a regular feature of size, but a "handle" we use to mathematically "touch" the datum feature is independent of the non-traditional notion of size that this shape has. I'd argue that any of the position FCF's could be properly confirmed with a simple fixture. The partial sphere is frustratingly similar to a blunt cone, but the "handle" of the cone is the point, and you can't have a "bigger" cone with the same point in the way that you can have a "bigger" partial sphere with the same center.
I take it that that RXXX feature actually is SRXXX?
Is your piece solid, or a piece of spun sheet metal? This would affect how I would apply datums and tolerances.
JHG
Yes, good catch, it is a sphere. Solid piece.
Let's say that the partial sphere fits into a matching pocket and that the cross hole is clearance for a pin. A loose fit is OK; we just want to guarantee assembly.
The flat face is not controlled in my drawing, so it seems like the hole could orbit right off the part, but that's really an issue of the flat face chopping off the portion of the partial sphere where the hole was/is. So, the hole could intersect the part at an apparently remarkable angle and still satisfy the position FCF. A neat interaction there. Although, if the flat face is uncontrolled, I suppose you could be clever and deliver a full sphere!
The next thing I see is that datum A is not defined. I assume it is the spherical feature. If this were my drawing, I would call up datum targets, or call up a ring at some arbitrary diameter. You have to control the flat face somehow. Either it, or your through hole must be a second datum.
How difficult this all is depends on how accurate your tolerances are.
JHG
Regarding the flat face, yes of course it needs to be controlled. I was merely commenting on that interesting interaction
The part is purely hypothetical, only meant to explore the notion of "size".
I think that your sphere example makes sense, and shows some interesting things.
If the function of the part was as you described, with a clearance-fit pin holding the part to a mating part with a spherical cavity and corresponding clearance holes, then the position tolerance works. (other than the datum feature label being missing as drawoh mentioned).
I also like your comments on the "handles" that we use to describe certain shapes such as spheres and cones, and that these sometimes conflict with the way GD&T really works. These handles relate to the datum points, axes, and planes shown in Fig. 4-3 of Y14.5-2009. In the case of your partial sphere example, the spherical surface has a nominal center point and a basic radius (spherical radius? But that center point and radius really have no relevance to the part and its function - it's all about the surface, and its relationship to the hole. The feature functions like a surface, that happens to be nominally spherical. Just because the surface s nominally part of a sphere, this doesn't mean that it functions like a sphere and we have to somehow extract a center point datum (handle) from the actual part surface. The center point and radius just provide a more convenient way of describing the basic geometry (and the geometry of the theoretical datum feature simulator). If the datum feature surface was a blunt cone, then an an axis and apex could be defined on the drawing but it would have the same non-relevance. If the datum feature surface was a more complex nominal shape, such as a blunt oblong quasi-cone like in 4-3 (g), then an axis, point and center plane handles could be defined on the drawing. But again, they would have the same non-relevance. If the datum feature surface was an blunt arbitrary surface of revolution, similar to 4-28, then the point/axis/plane handles could be defined but they would be completely arbitrary.
So where am I going with this, you may be wondering? I think I'm agreeing that in GD&T it's really all about the surfaces - the fact that the position requirement can be verified with a gage, that only has surfaces and not handles, shows this. So we need to describe datum feature constraints in terms of the surfaces - sometimes the handles get in the way.
Evan Janeshewski
www.axymetrix.ca
