Need Help - Cooling Flat Plate with LN2
I have a flat plate (~16in^2) that has enough heat input to get upwards of 500°C during processing. I have been asked to look into cooling it with LN2. I don't even know where to begin. Some of my questions are:
How do I provide a specific flow rate of LN2 at pressure to cool surface?
What kind of nozzles do I use with LN2?
We use quite a bit of LN2 in other processes, is LN2 a cost effective means of cooling in a production environment - semi-continuous process?
What are some good online resources for ideas and hardware for designing LN2 cooling processes?
Thanks in advance.
Thanks in advance.
"To be or not to be, that is the question" - William Shakespeare via Hamlet
RE: Need Help - Cooling Flat Plate with LN2
What's the heat capacity of the plate?
How quickly do you want to cool it?
How much LN2 do you have?
TTFN (ta ta for now)
What is temperature is the plate desired to be during production?
What is the power dissipation that's heating the plate?
Keith Cress
The amount of heat that you need to remove in what time period is the important info.
Heat of vaporizations (kJ/kg):
water: 2257
nitrogen: 199
So, water is basically 11x more useful for cooling things above 100C
LN is only a good option if you need very low temps, and you have to vent into a controlled space.
True, that, but steam isn't really that much more useful that gaseous nitrogen from a cooling perspective. Once below 100C, water is marginally better than LN2, 293 kJ/kg(70C delta temp) vs. 199 kJ/kg, but, presumably, water is much cheaper to condition for cooling.
COME IN elfman!
Keith Cress
