AMADA AF2000E QUATTRO
I'M RUNNING AN AMADA QUATTRO AND THEIR IS A LOUD NOISE WHEN MOVING ALONG THE X-AXIS. UPON INSPECTING WHAT WAS GOING ON I FOUND THE MANIFOLD AND WIRE BUNDLING HARNESS ARE RUBBING AGAINST THE LONG ACCESS PANEL ON THE TOP OF THE ARM. IS THIS A COMMON PROBLEM? IF SO ARE THERE ANY RECOMMENDED FIXES? IF NEEDED I CAN SHARE SOME PICTURES OF THE CONDITION.
