Dislocation of Cold Clamped Shoe Support
Dear Piping Engineers,
Have a look at the video in below link:
https://youtu.be/oBdpx6xDvC0
There are many incidents of this type in our plants.
The reasons may be:
1) Loosening of bolts of clamps
What is the solution?
1) How to check (through calculations) that the number and size of bolts is adequate?
2) How to calculate proper bolt torque for sufficient group?
3) Will spring belleville spring washers be an answer for avoiding loosening of bolts?
The reasons may be:
a) Due to Installer mistake
b) Due to compression of the cladding under the load of the piping
c) Due to minor shrinkage of the PUF blocks
d) Due to different coefficient of friction between clamp & cladding and shoe bottom & structure top
2) Wrong size and number of boltsWhat is the solution?
RE: Dislocation of Cold Clamped Shoe Support
Reasons #1 & #2 are not valid.
The reason for the failure shown in the video is the wrong type of support was selected.
The type of support required for this application is one that (a) does not conduct the Thermal properties of the Cryogenic Piping but is anchored in place to the pipe so it does not lose position lineally (on the pipe) during heat cycles.
Do some research here:
https://www.google.com/search?q=images+of+cryogeni...=_
Sometimes its possible to do all the right things and still get bad results
IMO, it might be resulted from the cost concern of the installation material and labor. I thought it may help if the length of the clamp shoe is increased for sliding between the shoe and supporting steel. However, the engineer still needs to resolve the issue of the different friction forces between the shoe/steel and clamp/cold insulation.
If the metal work is small enough in area then it won't act as a significant thermal path and only really penetrated the outer layer of three foam elements.
Try asking Carpenter and Paterson for a design....
"The type of support required for this application is one that (a) does not conduct the Thermal properties of the Cryogenic Piping but is anchored in place to the pipe so it does not lose position lineally (on the pipe) during heat cycles."
Anchoring a pipe in place is fine, but many standards are in practice which use only the support shown in video. And there are many incidents where the support gets displaced.
My point was that the loosening of bolts may have been due to three reasons, one - not enough torque applied at the time of installation, second - The PUF block may shrink little bit due to low temperature and this may collapse the cladding (seen in some incidents at site) and cause loosening of bolts, third - the compression of the PUF blocks may cause space at the top and hence cause loosening.
It is impossible to get the PUF block insulation with zero coefficient of linear contraction and with very high modulus of elasticity to have zero compression.
The answer to these is proper torque and use of the Belleville spring washers so that in case of shrinkage or compression enough torque should be there to avoid any slippage of clamp shoe.
The required torque for fighting up the PUF blocks may be based on the installation details which may be difficult to manage in the field. And, it may be a risk to damage it and create a new issue.
Yes, the support is clamp type hence free to move (slide) on pipe and the base of the shoe is not fixed with the structure. This is the reason for dislocation.
@Littleinch,
The piping systems are existing, we are performing stress analysis. Now with PTFE, the friction coefficient between shoe and the structure will become less than the clamp and cladding.
But providing PTFE plates now is VERY difficult.
My questions were:
If I need to rephrase, then tell me I shall try to do just that!
First work out your friction force from movement coming from the support. Then add safety factor ( 2?)
Then you can work out the compressive force and pressure required on your PUF jacket from the surface area of the support.
Make sure you're not going to crush the foam (compressive strength of the foam)
Then divide the force required by your number of bolts.
Bolt torque required for force is a well worn path and depends a lot on bolt lubrication - just do a search on bolt torque.
3) From what I've seen on other examples - yes Belleville washers, sometimes three or four sets, will compensate for the relaxation of the PUF under constant load.
Or put some barbs in the support and mechanically lock the support to the outer layer of PUF and glue the layers together.
Thanks a lot for this great help.
Appreciated!
