cilled water quality
what is the conductivity value for the chilled water ac system??. and please provide me with the reference code and standard that determine the chilled water quality (PH, conductivity, etc.)
I appreciate Your cooperation..
RE: cilled water quality
Chemical feed/treatment is used to maintain the Ph and minimize fouling.
To use any kind of de-ionized or purified water in a CHW system is bad for the system. De-ionized or purified water will leach material out of the steel and copper pipes and tubes.
So I don't think you are going to find a code dictating a value.
