USDFLD subroutine ABAQUS
How does ABAQUS interpolate the values of a material property based on the variation of multiple field variables?
Hi fellow researchers, I would like to clear something in ABAQUS regarding the manner in which ABAQUS interpolates a material property that has been defined to vary according to a finite number of field variables using the user subroutine USDFLD. Let’s say I have a model where I am defining the Young’s modulus E varying according to 3 field variables F1, F2 and F3 as the following:
E poisson’s ration Field 1 Field 2 Field 3
50 GPa 0.3 1 0 0
30 GPa 0.3 0 1 0
20 GPa 0.3 0 0 1
In temperature dependence case, I understand the value of E at a particular intermediate temperature would have been considered by linear interpolation. However, in the above case how will ABAQUS consider the value of E at a point where F1=0.5, F2=0.3 and F3=0.2?
50 GPa 0.3 1 0 0
30 GPa 0.3 0 1 0
20 GPa 0.3 0 0 1
RE: USDFLD subroutine ABAQUS
Your example is incorrect and interpolation can not be done in this case.
From Abaqus documentation (21.1.2 Material data definition, Interpolation of material data)
For three field variables with values in range from 0 to 2 we must define lines:
CODE
In first column you can define any E value to describe dependencies you need.
Now interpolation is possible.
Bartosz
VIM filetype plugin for Abaqus
https://github.com/gradzikb/vim-abaqus
this was really helpful. Now it makes sense. Thank you so much. By the way, there is a link attachment redirecting me to github for a plugin. I have never used this plugin. Is the plugin useful? Thank you again.
Shufen
It you prefer to work directly with abaqus inputdecks in text editor the plugin make work easier.
However it is for VIM text editor so you have to know it.
Bartosz
