steel frame design
steel frame design
Im working on a small open shelter house, and racking my brain thinking (or overthinking) the bracing. I want to do W columns and beams, and then either "X" bracing on 3 sides, or some corner bracing at each bay with angles from about 1/4 of the way down from the top of the columns in each direction to the beams at a 45deg angle. I see this all the time with wood shelters/deck structures, trying to figure out why never see it much with steel structures.
The structure is 16'x24', one bay deep (16') by 2 bays wide (2 @ 12'). So each bay would have kickers left and right sides, but essentially leaving the bay open.
Any thoughts?
Should these be welded or bolted connections?
Any thoughts?
RE: steel frame design
