Condensing curve data for heat exchanger
I have a project to replace rudimentary heat exchangers with a shell-and-tube heat exchanger/condenser. The heat exchanger company has requested some data that I'm not sure how to find or generate. They have asked for "Please provide a minimum nine (9) data point condensing curve for the Light and Heavy Oils showing the physical properties in the table received".
The light and heavy oils in this process are a mix of aromatic hydrocarbons when condensed become creosote. Most of the references on condensing curves are for a single chemical or binary mixture. How do I create a curve for a mixture of many aromatic hydrocarbons?
RE: Condensing curve data for heat exchanger
