ABAQUS constraints.
ABAQUS constraints.
ABAQUS constraints.
Hello all,
I am new to ABAQUS, I have two gears which are on the same shaft, one is the driving gear which receives the input from the rack.
I have to model rack and pinion constraint and constraint between pinion and gear, that is pinion and gear have same angular velocity but different linear velocity.
I have the rack, pinion and gear designs, I have to import these mesh them and apply the constraints.
Can anyone help me with this?
Karthik
