ASTM A335 P36 to 316 Stainless Steel
We have a requirement for welding ASTM A335 P36 to 316/316L Stainless Steel
I believe the ideal procedure would be to butter the P36 with ErNiCr-3 and PWHT, then join to the 316/316L after using ErNiCr-3 again..
However, I've heard of people welding dissimilar joints involving Carbon steel (Similar PWHT temp to P36) & stainless steels and carrying out PWHT on both, as long as you're using a low carbon or stabilised grade stainless.
My question: How can you confirm that the heat treatment cycle hasn't been detrimental to your stainless material in regards to sensitisation? Is there a test I can complete as part of my weld procedure to assess levels of sensitisation? (possibly ASTM A262 practice E?)
RE: ASTM A335 P36 to 316 Stainless Steel
