Set Settings for interferences with Journal
I'm using the simple distance tool in NX. I don't like to loose my settings for the interferences each time when a measure is applied. Is there a possibility to set these when opening the tool? I tried with a Marko but when applying it's losing the settings.
Thank you.
Thank you.
RE: Set Settings for interferences with Journal
If this is locked by your admin then you could use Favorites as an alternative. These can be saved by clicking on the cog at the top left of the form.
Mike Hyde
www.astonmartin.com
NX10.0.3 with TC11.2.1 and Vis 11.2
Mike Hyde
www.astonmartin.com
