Hydraulic expansion - blocked in liquid (water) scenario - API Clause 5.14.4.
We have a blocked in liquid scenario between two isolation valves and the medium is water. In our case the temperature is rising from 20°C to 110°C.
My issue with the formula {5.14.4.1-d-(3)} is the variability of the following three variables with respect to pressure and temperature.
αv {is the cubic expansion coefficient of the liquid, expressed in 1/°C (1/°F)}
αl {is the linear expansion coefficient of metal wall, expressed in 1/°C (1/°F)}
χ {is the isothermal compressibility coefficient of the liquid, expressed in 1/kPa (1/psi)}
How should I account for the above 3 variables' variability in the formula? Any input or help would be greatly appreciated!
RE: Hydraulic expansion - blocked in liquid (water) scenario - API Clause 5.14.4.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
We want to stay away from an RV for now, as installing an RV will be a lot of work in a nuke facility such as ours. We want to analyze as much as we can before we throw in the towel and go with an RV.
Good luck,
Latexman
You will find in API 520 (2008) p. 34 equation (3), the calculation for pressure. The several times I have checked for different fluids, the pressure has far exceeded the design pressure of the piping - pressure simply rises quickly as temperature increases. You didn't say if you were protecting piping or a vessel, but the same logic would apply to the latter.
If you are discharging to atmosphere, then you will encounter flashing flow in the discharge piping (relief temp = 110°C). You will want to consider in your piping calculations.
However the volume involved is very small - some sort of closed volume expansion vessel will take care of 90% of that pressure rise. If the volume in the pipe isn't very big, then neither will be the expansion vessel.
Just to think about alternatives:
Can you install a bypass check valve arround one gate?
Can you drill one of the two or more gates?
Also, when one gets a resultant pressure of say 13,000 psig for the blocked in liquid what code stress limits are used for the evaluation of the piping and the associated fittings/valves? Is it the normal stress limits or are you allowed to flirt with the yield/tensile stresses of the applicable materials?
