Online Aircraft Composite Repair Courses
Hi All,
Does anybody know of any good online aircraft composite repair courses? All of the good courses mentioned on this forumn (ie abaris) don't offer any training in Australia.
Thanks!
Thanks!
RE: Online Aircraft Composite Repair Courses
The area of composite repair training is a can of worms. I have been trying for many years to suggest some need for standards is appropriate. The best course in AUS by orders of magnitude is run by the RAAF NDT and CT section at RAAF Amberley. See Link
However, access to that course is on a Defence requirement basis.
My greatest exception to currently available training can be defined by the manner in which they teach heating methods. If the course teaches the use of a single heater blanket, irrespective of the substructure, then I would be suspicious. Seriously, heat sources must be arranged to match the heat sinks, and you can never do that with one blanket. Secondly is the location of thermocouples. If they teach that the thermocouples are arranged in a set uniform pattern irrespective of the substructure, I would be very suspicious. Next is the manner that the thermocouples are used for the process. If they control by the COLDEST thermocouple, then there is a very real risk of overheat damage, and I would seriously question the validity of that training. Thermocouples perform two functions: 1. to control the hottest point under each heat source to prevent overheat damage, and 2. to provide assurance of adhesive/resin cure. To achieve this, thermocouples must be located at sufficient points under each heat source to assure that the hottest point under each heater is measured and used for control. Separate thermocouples must be located around the repair to assure that the COLDEST temperature within the bondline is measured to assure that the adhesive/resin is adequately cured. These requirements can not be met by either a single blanket arrangement or by a set uniform thermocouple arrangement.
There are similar indicators about the quality of training that can be derived from data on surface preparation (especially for metal surfaces).
A good reference is Link
IN AUS I suggest you try to get copies of DEF (AUST) 9005, and AAP 7021.016-2 (I believe RAAF has renumbered the last document and downgraded the significance of the first document. If you can't get copies contact me.
Blakmax
Blakmax
Don't know if that is any help Bower7.
Regards blakmax
Adhesion Associates Pty Ltd.
AFRL-VA-WP-TR-2000-3029 COMPOSITE REPAIR OF AIRCRAFT COMPOSITE STRUCTURE (CRACS)
AGARD-CP-590 Bolted/Bonded Joints in Polymeric Composites
AGARD-R-716 Composite Structure Repair
FAA AC43-214 Repairs And Alterations To Composite And Bonded Aircraft Structure
DTT/FAA/AR-00-46 Repair of Composite Laminates
Airframe Structural Design: Practical Design Information and Data on Aircraft Structures, 2Ed, ISBN 9627128090
MIL-HDBK-803 GLASS REINFORCED PLASTICS - PREVENTIVE MAINTENANCE AND REPAIR
Care and Repair of Advanced Composites, Second Edition, http://books.sae.org/r-336/
SAE AIR4844 Composites and Metal Bonding Glossary
SAE AIR4938 Composite and Bonded Structure Technician/Specialist Training Document
SAE AIR5278 Composite and Bonded Structure Engineers: Training Document
SAE AIR5279 Composite and Bonded Structure Inspector: Training Document
SAE AIR5367 Machining of Composite Materials, Components and Structures
SAE AIR5719 Teaching Points for an Awareness Class on "Critical Issues in Composite Maintenance and Repair"
SAE ARP5089 COMPOSITE REPAIR NDT/NDI HANDBOOK
SAE ARP5143 Vacuum Bagging of Thermosetting Composite Repairs
SAE ARP6262 Basic Composite Repair Technician Certification Standard
T.O. 1-1-690 GENERAL ADVANCED COMPOSITE REPAIR PROCESSES MANUAL [restricted access]
Regards, Wil Taylor
o Trust - But Verify!
