Erosion under driveway
My mom called me over to her house because she said she had a "sinkhole" forming at the corner of her driveway that abuts the garage. I am going to attach a series of pictures showing the erosion. I am thinking the water causing the issue is coming from the roof valley (picture below). I can't believe how the soil was washed out all the way across the driveway along the garage foundation. I am waiting for a heavy rain so I can see it happening and verify the cause of the problem.
Now the question I have is how should I repair this? I was thinking I may tremie neat cement/grout under the driveway, after I have sealed the exit area. However I am not sure if I can get enough grout in there to ensure there is no gap between the existing aspahlt and grout. My second idea was to sawcut or use a sledge hammer to remove the asphalt and just fill the trench with concrete flush against the garage concrete.
I am going to install some roof gutters to route the water away from this area when I confirm this is what is causing the problem.
Any suggestions/recommendations are welcomed.
RE: Erosion under driveway
Extend a concrete apron from the garage outward for a few feet, the you can use asphalt....or concrete the driveway.
I had a similar problem with a concrete driveway. I cored holes in the slab and forced in (pounding in one little bit at a time down the cored hole 3" diam. with a 2-3/4" diam wooden ram )dirty sand containing a small amount of bentonite clay (4 percent) and a little cement 6% in a sloppy slurry.. It took several such cored places to finally stop the erosion. Soil here is fine sand. The loss of mix water in that sand stiffened up the mix and so only small areas of voids could be treated, meaning plenty of cores needed. Ended up with them on about 2 ft centers. The cement, bentonite and sand in the mix made the fill sand very impermeable. This also could work at the subject site, but then will a new path develop? In my case there was an alternative path for the water. If you use bentonite, go easy because it likes water and can expand GREATLY.
Urethane injection could work (if you plug the open ends), but the job may be too small for many contractors. The price has come down and there are more contractors doing residential work, so it may be an option. On the other hand, with the damage to the asphalt it would be to cut out the asphalt, deal with the soil and drainage, and have that area repaved(or extend the concrete apron).
Have you taken steps to prevent concrete collapse/cracking by the loads before the repairs are complete?
